Help!
I hope someone can help me!
I had installed the only Pearl Jam ringtones that show up in the market place. It froze on me so I installed an uninstaller app to remove it. My plan was to go back to the marketplace and re-install it but now it doesn't show up!!! Does the un-install remove it from the Marketplace and not just the phone??? How do I get it back? I need me Pearl Jam ringtones!!!
Yes when you uninstall an app from your phone it also removes it from your download list on the market.
Saying that ive just checked on the market and there are no pearl jam ringtones so i can only assume that app has been removed for some reason.
A good alternative i could suggest to you is the Zedge app,it is an app where you can search for and download thousands of different ringtones and wallpapers etc directly onto your phone.
Zedge Ringtones & Wallpapers - Android app on AppBrain
