Zerulus
Hello,I need Help.
So here's what happened :
I have a Samsung tab 4....I rooted it using kingroot app....It was rooted....then three months after rooting the phone started rebooting by itself consistently....then I thought formatting it would fix it....It formatted....sadly after formatting...It set up my phone only to find it filled with viruses such as porn club, sms manager ,pacprocessor etc.....They became system apps....so I thought I'll just delete them from kingroot....but kingroot was gone!so I thought it was uninstalled but when I try to install kingroot again it showed replace instead of install (like the app had app ready been installed)then I clicked replace it showed app not installed.....so installed tried with other root apps but the screen became dim every time I used a root app...and automatically exited from the app....what do I do? Also I cannot use Google services anymore. ...
