To help you with your problem we need to know what problem you have... unless the problem is owning a Lenovo P70 in which case you should buy a new phone
Go to your Google play store, look for your installed apps, locate the particular one that handles your emails(the one you are having problems with), if it says "update"..that's what you want to do..
