All of these Android users you might think one would use Google Translate...?
The message reads;
I have purchased the ZXDZ_2021 (Android 10.0) platform ac82271. The phone worked, but I can't USB connection, what can I do so that it can start the USB login displayed on the home screen, I would like download tom tom amigo navin, I tried hard reset, with no results.
The item being asked about is a Chinese car radio head unit running Android.
I'm afraid this appears to be an obscure brand and I was not able to find much information in my searches. You will most likely have to contact the manufacturer for instructions to help you. If you're having issues reading the included user's manual try Google Translate camera. It will live translate many languages including Chinese. Sorry I couldn't be more help.
Finnish;
Pelkään, että tämä näyttää olevan hämärä brändi, enkä löytänyt paljon tietoa hauistani. Sinun on nyt todennäköisesti otettava yhteyttä valmistajaan saadaksesi ohjeita. Jos mukana tulevan käyttöoppaan lukemisessa on ongelmia, kokeile Google -kääntäjäkameraa. Se kääntää livenä monia kieliä, mukaan lukien kiina. Anteeksi, etten voinut olla enempää avuksi.
