I messed up the firmware for my devour and now it is stuck at the blur boot screen and won't go past that. How can I re-flash the firmware for my phone?
I assume you rooted the phone. Was the root successful or was it the cause of your problem? While stuck on the Blur screen does adb recognize the phone and allow you to access the shell?
Yes I rooted the phone. No adb does not recognize it. I actually ended up getting a $70 upgrade to a droid when I took it to Verizon. That should be coming sometime this week. The root was not the issue, I did that successfully. I was trying to do the themed notification bar thread and I messed up the framework-res.apk
