help
rabhoy68
what does security warning there are problems with the security certificatefor this site the name of this site does not match the name on the certificate mean
It usually means you could be on a scam site, not the site you think your on. For example, if you clicked a link to go to Android forums (this site) make sure the address bar says "androidforums.com/"
A few examples of possible scam sites could be:
"androidforum.com", an internationally misspelled name to try to trick you. Notice that the real forum has an 's' on the end
"androidforums.scamsite.com", it says androidforums, but its a sub-site of a different site, also designed to trick you.
I agree fully...
However, It is also possible that the certificate date had expired and you now need to download a fresh one from source. But whatever the reason is, You really must make sure that the site you have accessed is genuine in the first place.
