help
quackman
Hey so I just got this pcd chaser and I was wondering if first of all if u would recomend rooting my. Phone and secondly if it is possible to do without a computer thank u in advancetug
Hi quackman, and welcome to Android Forums. :)
I would personally recommend rooting your phone, it makes it so much more powerful! :D
I'd recommend asking over at the All Things Root Chaser forums on how to root your device, as I'm not familiar with it.
Welcome and as Matty referred you too checking the rooted section of your device will give you the best possible answer for your question
