help!!
So i had the glyde before i got my droid and i'm still useing the same sd card but the videos i took with my glyde now don't have any sound with my droid. Please help me i can't figure it out and i want to listen to videos
Here is the easy way to fix this. Mount the phone and move the videos to your "My Videos" folder on your PC. Then download and install Doubletwist. Now open doubletwist click on videos and locate the files. Drag and drop them back to the phone. It will convert the audio to the correct format automaticaly. I converted all my Treo vids this way and they look even better and sound great fixed low sound I had on some. Hope this helps.
