Help?
  • Start date Start date
1. If your cell phone has Android 4.0 or later press and hold the Volume Down and Power buttons at the same time for a screenshot. (Skyrocket is upgradable to 4.1)
2. Some manufacturers have a special shortcut - check your manual to see if yours does.
3. If your phone is rooted you can install an app like Screenshot:
https://play.google.com/store/apps/details?id=com.geeksoft.screenshot
4. For a non rooted phone you can buy this app:
https://play.google.com/store/apps/details?id=com.edwardkim.android.screenshotitfullnoroot
5. You can also use Android SDK:
How To Take Screenshots In Android Using Android SDK
