Help Help
biggiephil
Does anyone know how to fully change the entire systems font with a 3rd party app? I haven't figured it out
I am not sure, but I did see the fonts in the system directory. If you want to do it manually, back it up, and rename the font you want as the same name that the system is looking for would work. I suggest editing the ttf's name with a font editor to match as well. I used myfont on the lg motion but it didn't work.
