Help.....
misterjez
Hi, I have just installed a software update on my Samsung note PRO, it was 155mb there or there about.... Now I have totally lost my WIFI connections, it does not recognise anything, says they are all out of range, tried adding manually, exactly the same story, any ideas?
I would try a soft boot first. If that doesn't work reboot your router and failing all else a factory re-set (make sure back up your data first)
