help
Try kingroot. That might be able to. Note: since kingroot is an on phone root, it's not as powerful as some computer methods, so this method may fail and not work.
*Make sure you understand the consequences of rooting (insert more warning here) and root at your own risk.
Steps:
1. go to settings, enable developer mode, and check off usb debugging. Then, go to settings, security, and check off unknown sources.
2. now on your phone, google "kingroot apk" and go to the link with xda in it (only download from this link since the app is Chinese, and someone translated it and shared it on xda.
3. download the apk
4 install the apk and open the app
4.5. if the app asks your to update, just update, it will stay in english
5. anyways, once you open the app, press root
6. wait and hopefully your phone roots.
if it didn't work
1. you can uninstall kingroot since you don't know it anymore.
2. google your phone usb driver and install it onto your pc.
3. download motochopper, iroot, or whichever rooting tool your choose
4. install or extract whichever rooting tool you choose
5. connect your phone to the pc
6. now, depending on whichever root tool you choose, you can either press root, or you need to run this file "run.bat" (the file may differ, this is the file name motochopper uses)
7. sit back and hopefully your foot get rooted.
If your phone is sucessfully rooted, make sure it's rooted by installing root checker from the google play store. Also, check to see if you something like supersu, kingroot, or what not to manage your root access. If you, just google supersu or kingroot, etc into the google play store and install. Open the app and you can now set up root apps.
enjoy
Good luck
