Hi :) Alarm problems
sometimes I cant hear the alarm go off even though I have sound on etc I have noticed in the menu it shows as silent after 5 mins and and the alarm is set to go off every ten mins
Hello back at you and hope you enjoy the site, I will direct you to your device forum, I am sure there will be members there that have suggestions for you, you can also download different apps from the play store and test them out, good luck
Samsung Galaxy Ace
Sub-Forums:
Ace - All Things Root
