Help hi...first smart phone..help
gwingee
I tried to download a market place app last night..and it took forever and only got to 9 percent and stopped..when I try to get to youtube..it does not go either...also, I had some ringtones I wanted to use..but if I take out my SD card..they disappear...need help please....when you download an app does it not stay on the phone..does it go to the SD card only? That is what someone said..that is crazy
sorry for this..but HOW do I say phone or SD card...will it ask? and how do I put my ringtones..only 2 from the sd card to the phone so when I take out the card they can still be used?? Also, my screen is set to 30 seconds BUT it keeps going on much quicker like 6 or 7 when I am trying to do something and my finger is not on the screen...
why would you remove your sd card? there is no reason to do that just leave it in and that will fix that problem lol and as far as the youtube and apps are concerned make sure you are connected to wifi or are running 4g. . if you are on the 1x network it won't really work that well
