Hi - My Android Mini PC Nightmare - Can't Flash, Won't Flash
Tayonas
Hi forum. Not a lot I can say except I am stuck and a bit paranoid about a TV stick I bought.
This is the stick I got from Amazon UK.
I don't care about streaming movies etc. what I do care about is it being able to work as an Android device and interface with my touch panel monitor, but there is a list of problems before I even get to the touch panel.
To start with I cannot get sound from it, so I had a look. When I say I had a look, what I mean is; it arrived Monday morning and I worked on it until Thursday night non stop with no sleep.
I have been through all the settings I can see including changing the audio from default to HDMI.
It will not allow me to flash it with any of the 13 images I downloaded for it.
I rooted it, but get no dev functionality. I installed root apps, no joy.
I opened it up to short the NAND and there is a heatsink glued on top of all the chips.
Mobo: G809.
About Device:
Model: HX_3188
Android: 4.4.4
Kernel: 3.10.0 / ren@gxt #623
Build: HX_3188-eng 4.4.4 KYU84Q eng.ren.20160419.083819 test-keys
Vendor Version: RK3188_R-BOX_ANDROID4.4-SDK_V1.0.0
I am new to Android boxes, but not new to flashing etc. When I try and flash I get a chip error. It could be something obvious that a box newbie would miss.
Aside from no sound and me being unable to flash it, it is a good box. It is fast, I thought at first it was slower at certain apps than my Pi -obviously I was limited to what I could test between the two, but then realised it was only slower on the first run and is quite speedy.
So, the question is ... am I going to be returning this, or have I missed something?
...and interface with my touch panel monitor...
I know this is a stupid question, but does your 'touch panel monitor' have speakers?
Also, why did you root the device?
And finally... You found 13 compatible upgrade roms for this device? I can't find even one!
Yes, the monitor has built in speakers and it's a Touch Genie overlay.
Until I get the sound working though I am just using a flat panel tv.
I rooted it so that Tun.ko and other apps could takeover the ROM process.
I found 13 images and I expected at least one should have worked. At first it was an error with Windows 10, it looked like it was working, but wasn't. I went and used a Samsung N150 and the flashing process is working correctly, but all fail the 3rd or so chip check.
Even the firmware for the same model number won't work/flash.
