Root Hidden features for LG L70 MetroPCS!
Hello
I'm new to the forum. I have discovered hidden quick settings on the MetroPCS version of the LG L70. I found NFC, Eco Mode, QPair, and QRemote. I used resflux from Xposed Framework to turn these on. Any idea if these features even work? There is also one called LED. Any info? Thanks!
None of that works. Tried it already. :(
BUT you can use resflux to enable weather on lock screen and the extra slide lockscreens. You must enable it in both lockscreensettings and keyguard for it to work.
Sorry for the VERY late post but how exactly do I make it work? using boolean? (It crashes)
