Hi all,
I have noticed my battery doesn't last very long especially when i play a game or need to search web etc so i decided to buy a high capacity battery. I purchased a 2500mAh battery instead of the standard 1500mAh battery that the phone comes with but i have now found this battery is just as bad and is in fact only a 1500 mAh battery which i found out via a battery app (i am currently in contact with were u bought it) but what i was wondering is if any of you have bought a better battery yourselves that does last longer than the standard rubbish 1500mAh battery's and if so were from. I would rather have one were you don't have to get a new back part of phone to fit it in though if possible as a few i saw are thicker than the standard ones and therefore needs to have a different back to it.
Thank you in advance for any help
Hels x
Hels x
