High speed charging cable?
JAy3001
Android Expert
With the huge choice of cables out there it can be quite confusing as to which would suit best and which actually are high speed.
But i'm looking for a long micro usb charger setup or cable for my HTC OneX+ that is 1.5m so that I can game and charge at the same time. My current long cable it complete crap for this, but my original cable is to short?!
So any recommendations?
The legth of your cable doesn't affect the charging speed or anything like so, hare's why;
speed in charging is known as frequency. Your battery is charged using Direct Current, and the frequency is never constant it changes but has a minimum and maximum frequency depending on voltage and current from the AC source. Increasing the length of your cable, increases the amount of power used, but never affects the frequency or speed of charging.
If you need your battery to charge faster, you should buy a charger with a higher frequency or voltage outputthan the one you are using. This though will kill your battery...The amount of time set for your batter to charge is deternmined by the voltage and the current.
I hope its not too geeky or nerdy, and that you understand.
A very simple explanation. Different batteries have a different charging speed based on A/h. A few years back, most of the phones can only charge at max 1A/h speed. So if you have 2000 mAh battery and have 1A charger, it will take you in theory 2 hours to charge your battery at max speed. Right now, most of the batteries/phones are 2A/h. So, that will be your charging speed and you have to be sure your Wall AC charger is rated and can supply 2A, usually marked on the charger. If you are plugging it into usb port of your laptop, that port can only supply 500mA, so you will be charged at 1/4 of the speed.
With that out of the way, here is a truth about charging cables. The thickness of the wire will determine the amount of current it can pass without bottle-necking the speed. If you are using thin usb cables for data transmission, they are intended for laptop/PC usb ports with 500mA speed and rated at max of probably 1A.
Every wire has AWG rating based on the thickness of it: American Wire Gauge table and AWG Electrical Current Load Limits with skin depth frequencies and wire breaking strength - look at this table of AWG vs current. For 2A nominal charging speed, you need 24AWG wires (max 3.5A rating). Most of the usb charging cables don't specify AWG wire rating because they use cheap thin wires. If you want to know for sure, get monoprice cable: 3ft USB 2.0 A Male to Micro 5pin Male 28/24AWG Cable w/ Ferrite Core (Gold Plated) - Monoprice.com - which specifically tells you 24AWG for power wires (+5V and ground) and 28AWG for data wires.
Otherwise, just buy a bunch of cables and see which one will yield faster charging - that on will have thicker wires ;) Also, if you have Galaxy phone, there is an app which can tell you your charging speed. Otherwise, you can also get Charging Doctor gadget (for a few bucks, look into a list of all my reviews, link in the signature, also a sticky in this forum).
Hope this helps!
Thank you for the very informative reply twister. The cable I have must be absolute cheap nastiness then!
Oh, sorry for the slight delay in replying. ;)
