hoe to enable weather info on home screen in Samsung Galaxy Ace ?
xahrakazi
I bought my mobile yesterday , but i didn't contain weather ingo below the google search bar , i searched aswell .. how to enable weather info on my screen ?
If you long press (touch and hold for 3 seconds or longer) a pop-up will prompt you for option. Choose widgets and then see if you have a weather widget. I'd be surprised if it didn't, but if not, you can just go to Google play and search on "Weather Widget". there are loads of them.
