Holster for nexus 5
redf4rr
I ordered a N5 and a Spigen NEO Hybrid case. I would like to find a holster/clip to hold it. I currently have a seidio surface with clip on my S3. I would like to be able to use a clip with my new phone. Any suggestions? Will the Seidio surface work with the Spigen hybrid?
Hi
I don't know if this helps but I have the Spigen Ultra Hybrid case and the I-Biason case/holster (bought from Amazon) and have found that the Spigen case fits in the I-Biason holster fairly well. It isn't as snug a fit as the case that comes with the holster as there is a bit of give but is still secure. I'm not a huge fan of the rubber case part that comes with the I-Biason it seems to add more bulk to the phone than the Spigen case.
Ideally I would like a holster like the Golla (nylon cloth) one that I have used with my Desire S for the passed 2 years. I would probably do without a case all together like I've done with the Desire S if I could find one.
Can u post a picture of the phone in the clip? Is it really loose? I am an electrician and wear the clip on my tool belt. I had a seidio surfsce on my s3. I just don't like the metal kick stand on the nexus case.
There is about 3mm give when using the Spigen case with the I-Blason holster but for normal everyday use the slightly loose fit I think is not a problem. It only really noticeable when you use your fingers to pull at the case.
As you are in a more physical working environment it could perhaps potentially be an issue with prolonged use.
I don't know what the exterior size difference between our Spigen cases is but if it slimmer then mine then I doubt that it'll work with the holster.
I hope the pictures help.
Hi
If you are referring to the I-Blason, then yes It's the "Dual Layer Holster Case with Kickstand and Locking Belt Swivel Clip".
