After the ota update I went from getting full day battery life with pretty heavy usage to 10 hours. The update was supposed to improve battery life but it made it worse. I tried going a day without using home++ (home replacement app ) and my battery life went from 10 to roughly 36 hours!!! So if you are one of those people complaining about battery life after update like I was,and you are using this app try taking it off.
hope this helps some ppl.
P.s. if it works try emailing the developer too fix because the app did not drain battery before the ota update
