electricpete
Android Expert
Here's the video
I bought three things:
Superglued a bent metal strip onto bottom of charging pad to hold the phone at the right height for charging, so I don't have to fuss with placement.
Added a spacer superglued to the bent metal strip so there is a space for air to flow between the power pack and the wireless charger.
Fan gooseneck is bent in a U shape back towards the charger, cooling both the phone and the wireless charging pad.
Results: net charge rate approx 17%/hr (*) with screeen on (daydream mode) and battery temperature remains 95F with 75F room temperature.
The whole thing can be picked up and carried around and used while charging/cooling.
Yes, I realize not everyone cares so much about battery temperature. The battery on my phone (Nexus 6) is not the easiest to replace so I'm extra cautious. I can turn the fan off if it's distracting or I can remove it alltogether and I still get the thermal benefit of having some free space below the bottom of the charger to facilitate natural air flow.
1 - Kmashi 15,000 milliAmp-hour power pack ($20, delivered)
2 - USB clock fan with flexible goose neck ($8.50, delivered)
3 - Insignia wirless charging pad from Best Buy $40 - (Yes, I know there are cheaper options... this was an impulse buy)
Items 2 and 3 powered from item 12 - USB clock fan with flexible goose neck ($8.50, delivered)
- * I have a 3200 milli-Amp hour battery. So 1% per hour is 32 milliamps and 17% per hour is 17*32 = 544 milliamps (this is NET charge rate... the actual charge rate is higher but net is reduced by the amount consumed by the phone while it is charging)
