Home Pipe
mdsj
Member
So I just downloaded Home Pipe Agent and it gives you access to your home network from your phone. It works great.
My only issue is that it is also supposed to allow you to upload files and folders from your phone to the computer but everytime I try the app tells me I don't have permission.
Other than that it is a great app. Anyone else using it and have more detailed info on my issue by any chance?
You have to go log in to homepipe.net. Then click on "Sharing/Settings"...its in the bar on the left once you log in...under the list of your shared folders. Once you click on that, click on the "Change", and then you should see "Permissions"...click on "Read-write". You probably only have "Read" selected.
