home screen icon how to?
JXWD
Hi can anyone point me to a tutorial (i am doing best with the video ones :-) ) / instructions on how to create a homescreen icon for andriod?
Thanks -Hagen
You mean as a developer or just how to put an icon on the home screen?
The first I don't know. The second depends on what launcher you are using but I'd start be opening the app drawer, choosing the app and pressing and holding (if that doesn't work, do whatever you'd do to add a widget and look for an option there to add an app instead).
oops sorry I am in the wrong forum aren't I... moving to <> App Development...
You could just "report" your own post and ask one of the mods to move the thread.
(You also have my permission to ask them to remove my posts as irrelevant if you do that, since once moved they would be ;)).
