Home Screen
Just drag an icon to the right until a new screen is created. Long press the home screen until the home screen editor activates (this is when the home screen becomes smaller and you can move stuff around). Then, just grab an icon or widget and drag it to the right, past the right-most screen you have, a new screen will home screen will create. You can't have empty screens, so you need at least one icon or widget on each.
I don't have mine yet and want to wait to play with it myself before I start asking a million questions. But does anyone know if you can get rid of the far left Google assistant screen? That is too I-phoney for me. I hate a dedicated left screen like that. I want left or right to be me my screens I set up
Can I shut that off? or is that not an option?
I'm not positive, but I don't think you can if you continue to use the Pixel launcher. Obviously, a third party launcher would eliminate it.
just got mine and turns out you CAN shut off. pretty easy actually. hold down on any blank screen. widget, wallpaper and settings are your options. right in this "setting" is an option to turn off the left google now screen. in case anyone is wondering.
