I am helping an elderly friend who lives in a different city as I do.
She has a desktop Windows XP sp2 Older pc. Does not have built in wireless card.
She has an LG F6 Optimus phone using Tmobile. Her mobile Data limit is small, maybe 1g, but will still have connectivity to data just slower till the new month cycle begins.
There is NO internet connection (No wifi, no router, no service provider, etc) in the home.
We are going to be using her cell phone as a hot spot for her PC so that she can:
Surf web, read email, maybe you tube, maybe go to CBS web site to see a show that she might
have missed seeing when aired. Since her PC is does not have wireless card installed, we need to
get her an wifi adapter (maybe easier than getting an internal card)
I need advice on which wifi USB wireless adapter is a good one (not expensive either) to get her.
I had got online a generic cheapy nano dongle that came with a CD. I fussed with it trying to set up a profile, & at times it was working, then not working. But got it to work fine finally. So I thought. Anyways, I left town and when she tried to use it the next day, it had to be configured all over again and troubleshoot. By phone we tried troubleshooting to get this working again and the dongle would not connect, and needed to be configured (which I tried so many steps the night before when I dont even remember what worked or didnt).
But I am now looking another one that is an easy Plug n play usb dongle that will require less fuss to set up AND STAY set up. They all claim to be plug and play with little configuration, so maybe the cheapy generic one we tried to use could not cut it.
I have researched a few but would like your input on a USB dongle to make her Desktop wireless so that she can use her phone as a hotspot. As I said her Cell phone will be the only internet in the home (though there is dial up now, but we are going to remove that soon since it is worthless.)
Some reviews I saw online suggest getting one that is 801.11g or n. Some stated that certain usb models of Linksys gets too hot, drops connection, etc. Since she can place her cell near the PC, distance shouldn't be an issue.
Please advice, thanks in advance
