AdrianShepherd
I'm having some problems with my Samsung A3 2016 (A310F), on Android 7.0.
I rooted the device using Odin3 v3.12.3 and flashed TWRP 3.0.2.1 SMA310, and then installed SuperSU v2.76 using the TWRP that had been installed.
Unfortunately, whilst the phone did get rooted, there are a number of problems:
I have tried to clear the Cache and Dalvik Cache via TWRP, and reset network settings, neither of which has worked.
My research has suggested that perhaps SuperSU v2.76 is the problem, and that I would need to use SuperSU v2.82. However, I cannot find any way to get SuperSU v2.82 onto the device.
I suspect I need to start from scratch somehow, but I'm very new to Androids and rooting and I'm not sure what to do.
Can anyone please give me some advice?
- The wifi button is stuck and greyed out in the "off" position.
- The camera doesn't start.
- SD Card storage is not showing.
- When connecting the phone to my PC via USB it doesn't open Explorer like it did before rooting (I can see it in Device Manager, but it is impossible to access the phone).
- The phone can no longer access the Internet using mobile data either. I am on Vodafone in the UK.
