So this means to turn the other sounds off? Actually they can keep sounding like they do now. Only the sound for SMS shall be different. The same as having a different sound for calls. I just want to be able to distinguish the SMS (sounds) from the others.There you set what you want to go through or not, but remember this is for sound only.
That would not be good, I assume.You could also go into each apps settings and turn off notifications, but then you won't get the visual notification either.
Yes, a different sound for SMS, all of the other sounds can stay as they are.If you mean a different sound for SMS, go into your message app's settings, find the notification settings and change the notification tone.
No, I don't.f you mean that you want everything else silent,
On my phone running Oreo 8.0.0:I thought sounds can only be changed in the general settings.Respectively I can touch that SMS / messages icon but cannot find in its settings anything to change the sound.
Ah yes, similar here, very hard to find somehow. Thank you. Made it.System Settings | Apps & notifications | App info | Messages* | App notifications | Categories - Default | Sound
Your path may vary, and/or there may be other ways to get there, but it should be similar.
A Sony Xperia X F5121. Sorry, should have mention it earlier. I have added the name in the forum settings but it obviously is not shown anywhere. Is there a signature or something like that?What phone do you have?
You're welcome.Ah yes, similar here, very hard to find somehow. Thank you. Made it.
