dragonzhwb
I want to write a application to draw those cell towers around me on google map. But unfortunately my teacher didn't allow me to use Google JSON to capture the location of the cell tower.
I want to know if i can get the distance between the cell tower and myself only use the gsm network.
If I can do it, I'll use the Tri-Lateration method inversely to get the location of the tower.
Thanks for your answer!
