Help How can I record both input and output audio simultaneously?
cutedroid
I'd like to record both the input audio and output audio at the same time. For example, if I'm on a VoIP call, I want both sides of the conversation recorded into an audio file. How can I easily do this?
Update: it needs to work for voip calls.
I have a rooted tablet
If your device is rooted and compatible, Wanam (Xposed module) works well. Otherwise, I recommend Call Recorder. If you go the Call Recorder route, be sure to get the one by skvalex, as there are several apps with that same name.
cr.skvalex.com/en/faq/detail/can-the-app-record-voip-calls-skype-viber-hangouts says
Can the app record voip calls (skype/viber/hangouts)?
No, it is not possible technically on Android.​
