Help how can i stop wifi going off??
tablet2011
I have my radio on from my tablet when I go to bed but after 30 mins the wifi on it goes off so is there anyway I can stop this happening?
It seem if you don't do anything with it during the 30 mins it goes into sleep mode then wifi goes off.
click on link BackLightKiller_1.7.apk - ptbw-codespace - Back Light Killer Version 1.7 - Advent Vega Back Light Killer and others .... - Google Project Hosting= download to desktop or etc, open vega in usb storage mode (disk should show in my computer) choose on vega a suitable location folder to drag and drop to.
then using the inbuilt file manager (in apps) locate the 1.7 apk and tap it, you will get a do want to install & bobs your uncle . if file manager does not work use the software tool in vega settings to do the above.
