Take a photo of it while in use - phone cameras are generally sensitive to IR (e.g. if my phone's IR focus assist is on and I photograph something reflective I can see it in the photo).
But most use dumb cameras. So the other way is to tell us what phone it is and maybe someone will know.
Well it doesn't work in the dark.I don't know, but that's a budget phone so I'd suspect it will use a less sophisticated solution. Fingerprint scanner should be more secure anyway and probably faster (I never see the lock screen on my phone as I just touch the scanner as I pick it up - by the time it could start scanning my face it is unlocked already).
Then I think it's safe to assume that there's no "IR laser dot projector" and "flood illuminator" in that phone then.Well it doesn't work in the dark.
Fingerprints do though![]()
Have you checked Motorola's page for its specs? That may help.It's the Motorola G7 Play
