Hey guys, I recently bought a new laptop and it does not support high-speed data, unfortunately. I am not in the mood to change my laptop again and spend more money now,it would be very helpful if somebody knows the solution.....thanks
What do you mean by it doesn't support high speed data? I assume you are referring to it not having a high speed cellular interface rather than it not having decent WiFi? If so, does it have any cellular interface? Just so we know what we're dealing with.
The simple and obvious answer is a portable hotspot (or your phone if you only need cellular connectivity occasionally).
I assume that you mentioned your wifi speed. If so, I would recommend you have a look at a Wifi card for Laptop. It can receive stronger wifi signal for your laptop.
