how d
  • Start date Start date
A
Android Question
Guest
How do i root my event phone so i could screen shot text messages
Hi and welcome to the forums. :) Need more info on exact device type. Until then you can take screenshots without root using this application : http://www.google.com/url?sa=t&rct=j&q=screenshot%20no%20root%20&source=web&cd=1&cad=rja&ved=0CCoQFjAA&url=https%3A%2F%2Fplay.google.com%2Fstore%2Fapps%2Fdetails%3Fid%3Dcom.edwardkim.android.screenshotitfullnoroot%26hl%3Den&ei=HNL-UbCKMoeVrAHomoGwBg&usg=AFQjCNH0d8IWidd-SFLwb0P4XArTEoyqRg&bvm=bv.50165853,d.aWM I do however suggest joining our forums so you can eventually get your device rooted if support is available for it to be rooted.
Hello and welcome to the Android Forums :D. If you are talking about the Kyocera Event it does appear that there is a root guide for the event here: http://androidforums.com/event-all-things-root/711900-rooting-your-event-pc-required.html. If that isn't your phone you were talking about then you feel free to look here: Android Phones - Android Forums for your phone, and there should be a all-things-root forum at the bottom of the page which will have rooting guides and custom roms and the like if available. Also you can create a free account if you would like if you have any further questions regarding how to root your device or how to do something on it :). I hope you enjoy your time here :D.
