saurabh28
I have Created One Fragment Activity which I want to call in tabbed Activity, I am new with Tabbed Activity so please Help,
MainActivity.java
package com.example.admin.tabtest;
import android.support.design.widget.FloatingActionButton;
import android.support.design.widget.Snackbar;
import android.support.v7.app.AppCompatActivity;
import android.support.v7.widget.Toolbar;
import android.support.v4.app.Fragment;
import android.support.v4.app.FragmentManager;
import android.support.v4.app.FragmentPagerAdapter;
import android.support.v4.view.ViewPager;
import android.os.Bundle;
import android.view.LayoutInflater;
import android.view.Menu;
import android.view.MenuItem;
import android.view.View;
import android.view.ViewGroup;
import android.widget.TextView;
public class MainActivity extends AppCompatActivity {
* The {@link android.support.v4.view.PagerAdapter} that will provide
* fragments for each of the sections. We use a
* {@link FragmentPagerAdapter} derivative, which will keep every
* loaded fragment in memory. If this becomes too memory intensive, it
* may be best to switch to a
* {@link android.support.v4.app.FragmentStatePagerAdapter}.
private SectionsPagerAdapter mSectionsPagerAdapter;
* The {@link ViewPager} that will host the section contents.
private ViewPager mViewPager;
@override
setContentView(R.layout.activity_main);
Toolbar toolbar = (Toolbar) findViewById(R.id.toolbar);
setSupportActionBar(toolbar);
// Create the adapter that will return a fragment for each of the three
// primary sections of the activity.
mSectionsPagerAdapter = new SectionsPagerAdapter(getSupportFragmentManager());
// Set up the ViewPager with the sections adapter.
mViewPager = (ViewPager) findViewById(R.id.container);
mViewPager.setAdapter(mSectionsPagerAdapter);
FloatingActionButton fab = (FloatingActionButton) findViewById(R.id.fab);
fab.setOnClickListener(new View.OnClickListener() {
@override
public void onClick(View view) {
Snackbar.make(view, "Replace with your own action", Snackbar.LENGTH_LONG)
.setAction("Action", null).show();
@override
public boolean onCreateOptionsMenu(Menu menu) {
// Inflate the menu; this adds items to the action bar if it is present.
getMenuInflater().inflate(R.menu.menu_main, menu);
return true;
@override
public boolean onOptionsItemSelected(MenuItem item) {
// Handle action bar item clicks here. The action bar will
// automatically handle clicks on the Home/Up button, so long
// as you specify a parent activity in AndroidManifest.xml.
int id = item.getItemId();
//noinspection SimplifiableIfStatement
if (id == R.id.action_settings) {
return true;
return super.onOptionsItemSelected(item);
* A placeholder fragment containing a simple view.
public static class PlaceholderFragment extends Fragment {
* The fragment argument representing the section number for this
* fragment.
private static final String ARG_SECTION_NUMBER = "section_number";
public PlaceholderFragment() {
* Returns a new instance of this fragment for the given section
* number.
public static PlaceholderFragment newInstance(int sectionNumber) {
PlaceholderFragment fragment = new PlaceholderFragment();
Bundle args = new Bundle();
args.putInt(ARG_SECTION_NUMBER, sectionNumber);
fragment.setArguments(args);
return fragment;
@override
public View onCreateView(LayoutInflater inflater, ViewGroup container,
View rootView = inflater.inflate(R.layout.fragment_main, container, false);
TextView textView = (TextView) rootView.findViewById(R.id.section_label);
textView.setText(getString(R.string.section_format, getArguments().getInt(ARG_SECTION_NUMBER)));
return rootView;
* A {@link FragmentPagerAdapter} that returns a fragment corresponding to
* one of the sections/tabs/pages.
public class SectionsPagerAdapter extends FragmentPagerAdapter {
public SectionsPagerAdapter(FragmentManager fm) {
super(fm);
@override
public Fragment getItem(int position) {
// getItem is called to instantiate the fragment for the given page.
// Return a PlaceholderFragment (defined as a static inner class below).
return PlaceholderFragment.newInstance(position + 1);
@override
public int getCount() {
// Show 3 total pages.
return 3;
@override
public CharSequence getPageTitle(int position) {
switch (position) {
case 0:
return "SECTION 1";
case 1:
return "SECTION 2";
case 2:
return "SECTION 3";
return null;
BlankFragment.java
import android.content.Context;
import android.media.AudioManager;
import android.media.MediaPlayer;
import android.net.Uri;
import android.widget.Button;
import java.io.IOException;
* A simple {@link Fragment} subclass.
* Activities that contain this fragment must implement the
* {@link BlankFragment.OnFragmentInteractionListener} interface
* to handle interaction events.
* create an instance of this fragment.
public class BlankFragment extends Fragment {
// TODO: Rename parameter arguments, choose names that match
// the fragment initialization parameters, e.g. ARG_ITEM_NUMBER
Button buttonStop,buttonStart,buttonPause ;
String AudioURL = "http://www.singhsahib.com/sukhmani-sahib/sukhmanisahib-a.mp3";
MediaPlayer mediaplayer;
// TODO: Rename and change types of parameters
private OnFragmentInteractionListener mListener;
public BlankFragment() {
// Required empty public constructor
* Use this factory method to create a new instance of
* this fragment using the provided parameters.
* @return A new instance of fragment BlankFragment.
// TODO: Rename and change types and number of parameters
@override
public void onCreate(Bundle savedInstanceState) {
buttonStart = (Button) buttonStart.findViewById(R.id.button1);
buttonStop = (Button) buttonStop.findViewById(R.id.button2);
buttonPause = (Button) buttonPause.findViewById(R.id.button3);
mediaplayer = new MediaPlayer();
mediaplayer.setAudioStreamType(AudioManager.STREAM_MUSIC);
buttonStart.setOnClickListener(new View.OnClickListener() {
@override
public void onClick(View v) {
// TODO Auto-generated method stub
try {
mediaplayer.setDataSource(AudioURL);
mediaplayer.prepare();
} catch (IllegalArgumentException e) {
// TODO Auto-generated catch block
e.printStackTrace();
} catch (SecurityException e) {
} catch (IllegalStateException e) {
} catch (IOException e) {
mediaplayer.start();
buttonStop.setOnClickListener(new View.OnClickListener() {
@override
mediaplayer.stop();
buttonPause.setOnClickListener(new View.OnClickListener() {
@override
mediaplayer.pause();
@override
// Inflate the layout for this fragment
return inflater.inflate(R.layout.fragment_blank, container, false);
// TODO: Rename method, update argument and hook method into UI event
public void onButtonPressed(Uri uri) {
if (mListener != null) {
mListener.onFragmentInteraction(uri);
@override
public void onAttach(Context context) {
super.onAttach(context);
if (context instanceof OnFragmentInteractionListener) {
mListener = (OnFragmentInteractionListener) context;
} else {
throw new RuntimeException(context.toString()
+ " must implement OnFragmentInteractionListener");
@override
public void onDetach() {
super.onDetach();
mListener = null;
* This interface must be implemented by activities that contain this
* fragment to allow an interaction in this fragment to be communicated
* to the activity and potentially other fragments contained in that
* activity.
* <p>
* See the Android Training lesson <a href=
* "http://developer.android.com/training/basics/fragments/communicating.html"
* >Communicating with Other Fragments</a> for more information.
public interface OnFragmentInteractionListener {
// TODO: Update argument type and name
void onFragmentInteraction(Uri uri);
fragment_Blank.xml
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:tools="http://schemas.android.com/tools"
android:layout_height="match_parent"
android
addingBottom="@dimen/activity_vertical_margin"
android
addingLeft="@dimen/activity_horizontal_margin"
android
addingRight="@dimen/activity_horizontal_margin"
android
addingTop="@dimen/activity_vertical_margin"
tools:context="com.example.admin.tabtest.BlankFragment" >
<Button
android:id="@+id/button2"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:text="Stop Music From URL"
android:layout_marginTop="52dp"
android:layout_below="@+id/button1"
android:layout_centerHorizontal="true" />
<Button
android:id="@+id/button3"
android:text="Pause Music From URL"
android:layout_centerVertical="true"
android:layout_alignLeft="@+id/button2"
android:layout_alignStart="@+id/button2" />
<Button
android:id="@+id/button1"
android:text="Start Music From URL"
android:layout_above="@+id/button3"
android:layout_alignLeft="@+id/button3"
android:layout_alignStart="@+id/button3" />
</RelativeLayout>
MainActivity.java
@override
@override
@override
return true;
@override
return true;
* fragment.
* number.
return fragment;
@override
return rootView;
super(fm);
@override
@override
return 3;
@override
switch (position) {
case 0:
return "SECTION 1";
case 1:
return "SECTION 2";
case 2:
return "SECTION 3";
return null;
BlankFragment.java
@override
@override
try {
@override
mediaplayer.stop();
@override
@override
@override
} else {
@override
super.onDetach();
mListener = null;
* activity.
* <p>
fragment_Blank.xml
android
addingBottom="@dimen/activity_vertical_margin"android
addingLeft="@dimen/activity_horizontal_margin"android
addingRight="@dimen/activity_horizontal_margin"android
addingTop="@dimen/activity_vertical_margin"tools:context="com.example.admin.tabtest.BlankFragment" >
<Button
<Button
<Button
</RelativeLayout>
