Apps How do i capped my maximum directory storage space in SD? PLEASE HELP!!!
imso
Member
Question 1: Presumingly i wanted to allocate only 1GB of space to store my videos in a particular self declared directory how should i do it?
Question 2: And i wanted my directory to capped at 1GB after which how is it going to auto-delete the oldest video file in that directory once its about to reach 1GB?
Sorry i'm kinna new in java and android and currently creating an car blackbox app can someone help me... Thanks
This is what I have tried so far can someone tell me how should i implement the above function into my mainActivity:
Code:
public class CameraTest extends Activity implements SurfaceHolder.Callback {
   private static final String TAG = "Exception";
   public static SurfaceView surfaceView;
   public static SurfaceHolder surfaceHolder;
   public static Camera camera;
   public static boolean previewRunning;
    @Override
    public void onCreate(Bundle savedInstanceState) {
        setContentView(R.layout.main);
        surfaceView = (SurfaceView)findViewById(R.id.surface_camera);
        surfaceHolder = surfaceView.getHolder();
        surfaceHolder.addCallback(this);
        surfaceHolder.setType(SurfaceHolder.SURFACE_TYPE_PUSH_BUFFERS);
        Button btnStart = (Button) findViewById(R.id.button4);
        btnStart.setOnClickListener(new View.OnClickListener()
           public void onClick(View v)
              startService(new Intent(getApplicationContext(), ServiceRecording.class));
        Button btnStop = (Button) findViewById(R.id.button5);
        btnStop.setOnClickListener(new View.OnClickListener()
              stopService(new Intent(getApplicationContext(), ServiceRecording.class));
    @Override
    public void surfaceCreated(SurfaceHolder holder) {
       camera = Camera.open();
       if (camera != null) {
          Camera.Parameters params = camera.getParameters();
          camera.setParameters(params);
       else {
          Toast.makeText(getApplicationContext(), "Camera not available!", Toast.LENGTH_LONG).show();
          finish();
    @Override
    public void surfaceChanged(SurfaceHolder holder, int format, int width, int height) {
       if (previewRunning) {
          camera.stopPreview();
       Camera.Parameters p = camera.getParameters();
       p.setPreviewSize(320, 240);
       p.setPreviewFormat(PixelFormat.JPEG);
       camera.setParameters(p);
       try {
             camera.setPreviewDisplay(holder);
             camera.startPreview();
             previewRunning = true;
       catch (IOException e) {
          Log.e(TAG,e.getMessage());
          e.printStackTrace();
    @Override
    public void onResume(){
       super.onResume();
    @Override
    public void surfaceDestroyed(SurfaceHolder holder){
          previewRunning = false;
          camera.release();
My RecordingService.java Service file
Code:
public class ServiceRecording extends Service {
   @Override
   public IBinder onBind(Intent intent) {
      // TODO Auto-generated method stub
      return null;
   private SurfaceView surfaceView;
   private SurfaceHolder surfaceHolder;
   private Camera camera;
   private boolean recordingStatus;
   private MediaRecorder mediaRecorder;
   private final int maxDurationInMs = 20000;
    @Override
    public void onCreate() {
       super.onCreate();
       recordingStatus = false;
       camera = CameraTest.camera;
       surfaceView = CameraTest.surfaceView;
       surfaceHolder = CameraTest.surfaceHolder;
    @Override
    public int onStartCommand(Intent intent, int flags, int startId) {
       super.onStartCommand(intent, flags, startId);
       if (recordingStatus == false)
          startRecording();
       return START_STICKY;
    @Override
    public void onDestroy() {
       super.onDestroy();
       stopRecording();
       //camera.stopPreview();
       //camera.release();
    public boolean startRecording(){
       try {
             Toast.makeText(getBaseContext(), "Recording Started", Toast.LENGTH_SHORT).show();
             try{
                camera.unlock();
             catch(Exception e){
                camera.reconnect();
             mediaRecorder = new MediaRecorder();
             mediaRecorder.setCamera(camera);
             mediaRecorder.setAudioSource(MediaRecorder.AudioSource.MIC);
             mediaRecorder.setVideoSource(MediaRecorder.VideoSource.CAMERA);
             mediaRecorder.setOutputFormat(MediaRecorder.OutputFormat.DEFAULT);
             mediaRecorder.setMaxDuration(maxDurationInMs);
                mediaRecorder.setAudioEncoder(MediaRecorder.AudioEncoder.DEFAULT);
                mediaRecorder.setVideoEncoder(MediaRecorder.VideoEncoder.DEFAULT);
                //mediaRecorder.setOutputFormat(MediaRecorder.OutputFormat.DEFAULT);
                DateFormat dateFormat = new SimpleDateFormat("yyyy-MM-dd HH_mm_ss");
                Date date = new Date();
                File directory = new File(Environment.getExternalStorageDirectory() + "/VideoList");
                if(!(directory.exists()))
                   directory.mkdir();
                File FileSaved = new File(Environment.getExternalStorageDirectory() + "/VideoList", dateFormat.format(date) + ".3gp");
                mediaRecorder.setOutputFile(FileSaved.getPath());
                mediaRecorder.setVideoSize(surfaceView.getWidth(),surfaceView.getHeight());
                //mediaRecorder.setVideoFrameRate(videoFramesPerSecond);
                mediaRecorder.setPreviewDisplay(surfaceHolder.getSurface());
                mediaRecorder.prepare();
                mediaRecorder.start();
                recordingStatus = true;
                return true;
       catch (IllegalStateException e) {
          Log.d(TAG,e.getMessage());
          return false;
          return false;
    public void stopRecording() {
       Toast.makeText(getBaseContext(), "Recording Stopped", Toast.LENGTH_SHORT).show();
       mediaRecorder.stop();
       try {
         camera.reconnect();
      } catch (IOException e) {
         // TODO Auto-generated catch block
