Help How do I check how much battery is left?
Hi this is probably a really simple and stupid question but how do I check how much battery I have left on my Galaxy Ace (the %)?
I did bring up a screen accidentally where it said 17% and showed some details but I can't find it now :(
(the bar on the main screen isn't very helpful)
I agree with Gammer. A battery usage app from the Play Store is more accurate. I'm using the (simple) Battery Indicator. It's reasonably accurate, although sometimes the percentage stays the same for a while and then suddenly drops about 5%; but that's a minor issue. It shows the percentage in the top corner of your screen.
I am currently using the same apps as Marcha but I have also found this one 'Battery Notifier (Big Text) by Shkil/larryvgs' as it gives notifications for full/low battery. In my case the full battery notifications has stopped working after updating to 2.3.6.
