Dan Coleman
I have an Android project for a library (using the com.android.library plugin), that includes C++ code. When I run the assemble task in gradle, the outputted AAR contains the native library in the /jni folder. However, there is no "prefab" folder. On the documentation page for libraries, the bottom section suggests that the /prefab folder should be there.
I can find information on how to set up a project to import prefabs from an AAR, but I can't find any information on how to build an AAR with prefab exports. Is there a way to set up an Android project with gradle to do this? Are there settings I have to add to specify which native libraries should be exposed?
I'm using Android Studio 4.1.1, gradle 6.8, and Android gradle plugin 4.1.1.
