Help How do I disable the charger/usb sound?
heyjoojoo
Wonderin' if there is a way to turn off that annoying sound that the device makes when I plug the charger into the phone.... gosh that's annoying.
i know this is old but i too have a samsung and have hated that noise. i found the sound file you have to delete then no more sound when you plug in charger. device must be rooted and use a root explorer app. go to system/media/audio/ui and delete the charger_connection.ogg after that no more annoying beep every time connecting to charger or computer.
