Root How do I fix an improperly rooted phone?
alcasey77
Hello, so I decided I wanted to install the leaked Jellybean update on my Samsung Galaxy S2. I followed the instructions I found on the internet, which were partially incomplete, and I only installed the PDA code when using ODIN. After this was downloaded onto my phone and I restarted it and continuously loops the restart screen.
It doesn't seem like my computer even recognizes my phone at this point and because of this I think that I can't install it properly onto my phone now. What fix do I have for this just to get my phone up and running on any Android software? Thanks for the help, I appreciate it.
Thank you very much. I have the Sprint Galaxy S2, I also used Odin3 and downloaded Android 4.1.2 I9100XXLSJ firmware for Galaxy S2. Let me know if you guys need anymore information.
