thejackson5
I know for a fact that my battery level is incorrect. It's a 2500mAh battery, and yet after a couple minutes of heavy use, the battery level will drop to zero and the device will shut itself off.
Weirdly enough, I have this same issue with my MacBook, and I've figured out (at least on the MacBook) what the problem is: the machine isn't calculating the remaining time/percent correctly. If I don't use it to do power-instensive tasks, it will be fine up until the battery truly drains. But if I run, say, high-graphics video games, it will detect the battery's getting used very quickly, somewhere along the line it will freak out thinking that this battery drain is leaving it with seconds to spare, and will shut down. If I press the power button to start up, it won't, only displaying the 'out of battery' symbol on the screen. But, in actuality, there's usually about 30-50% battery left in there. How do I know? If I apply the charger for a bit, even for two seconds and then detaching, forcing the machine to recalculate the remaining battery, it will turn back on and have 30-50% left for me to use.
Here's the thing, though: with my phone, I usually don't have anywhere to charge it. So I'll unplug it in the morning to last me all day, hop on a bus to explore the city, forget about this issue and launch a graphics-intensive game, and then only realise what I've done four or five minutes later when it shuts down on me, thinking the battery's completely depleted.
So here's my question: How can I force the phone to ignore the battery level, and keep sucking juice from it whilst there's juice to be had? I know, I know, it shuts down for my own good, to make sure it has enough battery so that it can power back on again later. But right now, this usually-useful feature is rendering my phone virtually useless. Any advice?
Thanks.
Thanks.
