propbuilder
I just got my Le Pan tablet and would like to know if anyone has set up a printer, either using wifi or bluetooth?
Thanks for any help
Thanks for any help
Thanks darelian for the information.
Question: Is printbot unlimited printing and if you are printing using wifi, are you using up banwidth? I guess you would be if you are using a print application. I occationally have to print photos and needed a quick and simple way. I suppose I will have to get an inexpensive computer/printer (download the printer program), then run the cable from the LePan to the computer. Thanks for the input![]()
