How do I remove or disable the Default notification sound?
jeffkinvg
I have custom notification sounds for my messaging, email, and calendar apps. The default notification is the only sound that works. How do I remove or disable the Default notification sound?
thank you for your response unfortunately I have already selected sounds for my apps and the default notifications. there is no None option for the default fortification sound and if i select the silent mode then there is no notification sounds at all it seems to override my apps sounds. this is why I would like disable the default not. sound so that my app notifications can be heard. Jeff
