how do I save info
HAT MAN
Member
so new to pda and love my eris but some reason I was in below freezing weather and screen timed out then a bunch of lines came on phone and wont go away. V is sending me a new phone since I have only had it 2 weeks so no worries there.
My question is will have to enter all my calender info, contacts, pics and apps I installed all over again or is there away I can save all of that info. I have videos music etc also on it.
I am still learning so dumb it down for me the best you can thanks
Vinny
Moving to Android Lounge:
All your Calender and contact info will be automatically synced back to your phone as that info is currently stored "in the Cloud". With your pics , videos etc simply take the SD card out of your broke phone and put it in the new one. With your applications you will need to re-install them all. But don't worry any paid applications you have purchased can be re-downloaded free of charge.
Just make sure you sign in the same Google account on your new phone that was on your last one.
Carl :)
