Apps How do I set a schedule to automatically delete files using Android Studio?
ReiSixx9
I want to add a command to my Android Studio app that will make it automatically delete files from a certain folder at a set interval. How do I do this?
Also, can I hide the folder (using a command) so that only my app can see it?
Sorry, I mostly only know stuff about c# and Windows Program Development, I'm new to this android stuff.
Thanks! :)
What command do I use to delete a certain folder then?
http://stackoverflow.com/questions/5486529/delete-file-from-internal-storage
https://developer.android.com/reference/java/io/File.html
All apps have an internal storage area, which is only accessible to that app.
External storage is different, and requires permission to read/write
https://developer.android.com/training/basics/data-storage/files.html
I can set the delete command to run at a certain interval (sorry my brain just totally forgot the word for that), correct?
So if I use internal storage somebody using the phone can't see the folder, but the app can use the data inside and send it via email or upload it to a cloud?
Correct
Your app's internal storage data can't be seen by any other app, but someone connecting to the device using ADB can see everything.
Also, where do I put the handler command? Like in the manifest or...?
I'm guessing this is the correct code, right?
Code:
final Handler handler = new Handler();
final Runnable r = new Runnable()
    public void run()
        <some task>
handler.postDelayed(r, 15000);
Or is it this?
Code:
 Handler handler = new Handler(Looper.getMainLooper());
        handler.postDelayed(new Runnable() {
            public void run() {
                AccelListener.this.timeout();
        }, 2000);
Is there any part of this code that I need to customize (change to fit my specific program) besides the time?
