Hello and welcome to Android Forums . In order to really help you I would need a bit more info . What are you trying to sync would be the main one . If you would like you can create a new question with a bit more info or register for an account (link can be found in my sig ) and go to the moto Atrix forums here: Motorola Atrix HD - Android Forums. Although from the look of things it seems kinda dead there, but you can still try and ask your question there or if you just want to sync contacts or the like then someone will be able to help you out here if you wanna just make a new question .
