how can i turn off my 3g separately without disturbing the mobile data. like data is on on 2g and when 3g is clicked on then switches to 3g. I use a samsung galaxy grand.
Hello, and welcome to the Android Forums . It looks like on your device you should be able to go into settings> more settings> mobile networks and there should be an option called "network mode" using that you should be able to switch between 2g and 3g . Hope this helps!
