How do I use SD card
  • Start date Start date
A
Android Question
Guest
Is the SD card in my Samsung Tab 3 used only for storage? Can I launch files from it?
Hello and welcome to Android Forums.
Yes and no.
The stock SDcard is intended for bulk file storage: think music and movies.
With an app2sd type ROM/app you can launch apps (files) from your SD, but it takes a lot of reading/learning and is not recommended for the novice.
For more info peruse our Tab3 8 forums: Samsung Galaxy Tab 3 8.0 - Android Forums
We also have tab3 7 and 10 forums.
If you narrowed down your device, we can give you better links.
