Help How do you stop beep when the battery is full ml
rcyphermd
Android Expert
When the battery is charging at night, it beeps when the battery is full. I must keep the phone on because I am on call. It is loud. Any suggestions and how to stop it? I came from a Samsung S8 and there was a option to turn all sounds off except for the ringtone. Thank you for the advance for helping
Check your "sound" settings: there's something called "charging sounds" in there. Try turning it off.
(My first thought was "what sound", but I obviously turned this off when I was doing my initial setup and then forgot about it).
I'm not familiar with that. Do you have any third-party battery management apps installed?
Nope, @Hadron's right - I didn't even know that option was there.
I didn't either: I typed the same reply you did, then thought "hang on, let's check the battery and sound settings, just in case...".
Something I do by reflex with any new device is go through the sound and vibration settings and turn off any dial pad tones, touch tones, haptics etc, so I expect I turned this off without giving it a second's thought when I first set it up.
