how does the droid overclock set scaling frequencies work on droid2 global?
kevdliu
Hi
I brought droid overclock today on my droid 2 global. There's this set scaling frequencies with voltages and stuff. I set on low with 800mhz, ???, 250mhz. But my cpu slider is set to max 1000mhz. I checked the frequency again with systempanel and the cpu went up to 1000 instead of 800.
Is this supposed to happen?
The droid 2 is supported but is the global?
Any help would be appreciated!
EDIT: Nevermind i solved it by checking the "Use latest module" option.
